Normal Topic Empty diagram on another computer? (Read 3722 times)
moelski
Jul 6th, 2011 at 4:16pm
Hi !
Today I copied my project to my old win XP machine. It started fine but if I try to add some (composite-) Nodes I see nothing.
The diagramView remains empty  ???
It runs perfect on my developement machine.
I tried it on another win7 machine and again ... No compositeNodes in the diagramView.
I copied these dllīs on the other computer:
MindFusion.Common.dll
MindFusion.Diagramming.dll
MindFusion.Diagramming.WinForms.dll
Did I miss something? As far as I know there is no restriction for the trial version, isnīt it?
Greetz Dominik
Re: Empty diagram on another computer?
Reply #1 - Jul 6th, 2011 at 4:39pm
Are you adding them from code or drawing with the mouse?
moelski
Reply #2 - Jul 6th, 2011 at 5:07pm
Hi !
I add the CompositeNodes from code.
Reply #3 - Jul 6th, 2011 at 5:12pm
Are you creating the diagram from data in a file or database? If so, are you sure the application successfully reads from the file or database when running on the other systems?
moelski
Reply #4 - Jul 6th, 2011 at 5:20pm
No I create the Nodes from XML strings.
And actually the XML strings are hardcoded within my classes - like in your CompositeNode demo.
moelski
Reply #5 - Jul 6th, 2011 at 5:31pm
I use code which is very similar to your Scripting example. And that works on another computer Tongue
So maybe I miss a redraw or something like that ?
And this is how I add a Node:
Creation ....
               Entity = new Node_In(proj.Diagram, x, y);
               Entity.Id = EntityGuid;
               Entity.Icon.Image = proj.Images.Images[14];
               Entity.Text = "TCP";
               proj.Diagram.Nodes.Add(Entity);
And the Code for the Node is here:
https://www.logview.info/Downloads/Nodes.zip
Greetz
   Dominik
Reply #6 - Jul 6th, 2011 at 5:36pm
Suppose the code did not run for some reason. If you display diagram.Nodes.Count from some menu command, is the value greater than 0?
moelski
Reply #7 - Jul 6th, 2011 at 5:42pm
No it is still 0 after I add the node  Embarrassed
Damn ... What the hell is going on there  ???
Reply #8 - Jul 6th, 2011 at 5:45pm
If you call MessageBox.Show just before or after Nodes.Add, does it show anything?
moelski
Reply #9 - Jul 6th, 2011 at 6:07pm
Shame on me Embarrassed Lips Sealed
                                <Image.Image>
                                        <Bitmap>D:\Dev Priv\LogView V3 .net\LogView V3\_Icons\_Found\missing.gif</Bitmap>
                                </Image.Image>
This is part of my node creation.
Sorry for that mistake. And thx for your support.
Dominik
