Normal Topic Infinite vertical scroll (Read 1645 times)
jpinera
Jul 7th, 2011 at 3:49pm
I'm trying to manage the vertical scroll using the mous wheel. When the mouse wheel event is raised, I modify the ScrollY property in the diagramView. But even when the bar is at the end, the diagram continue scrolling.
How can I detect the end of the scrollable area?
This is my code (the first part is to control the zoom if the control key is pressed):
    private void OnMouseWheel(object sender, System.Windows.Forms.MouseEventArgs e)
      // Update the drawing based upon the mouse wheel scrolling.
      if (_theControlKeyPressed)
        int factorToIncrese = e.Delta * SystemInformation.MouseWheelScrollLines / 120;
        diagramView.ZoomFactor += factorToIncrese;
        diagramView.Invalidate();
      else
        diagramView.ScrollY -= factorToIncrese;
        if (diagramView.ScrollY <= 0)
          diagramView.ScrollY = 0;
Re: Infinite vertical scroll
Reply #1 - Jul 7th, 2011 at 4:43pm
Add this after the 0 check:
diagramView.ScrollY = Math.Min(diagramView.ScrollY,
	diagram.Bounds.Height - diagramView.ClientToDoc(diagramView.ClientRectangle).Height);
jpinera
Reply #2 - Jul 8th, 2011 at 6:06am
Thanks a lot, now it is working
