Normal Topic setColor() with event LinkMouseEnter (Read 3485 times)
rlira
Jul 15th, 2011 at 6:11pm
Hello!
I'm trying to highlight a link when mouse is over it. I added events for MouseEnter and MouseLeave like this:
var = oldlinkColor;
function linkOnMouseEnter(sender, args) {
    oldlinkColor = args.getLink().getPen().getColor();
    args.getLink().getPen().setColor('#FF0000');
function linkOnMouseLeave(sender, args) {
    args.getLink().getPen().setColor(oldlinkColor);
However, I'm getting an exception on the first line of MouseEnter event.
Debugger tells me "getPen()" isn't available.
Is there any way to achieve my goal?
Thanks in advance.
Re: setColor() with event LinkMouseEnter
Reply #1 - Jul 15th, 2011 at 6:43pm
Are you using ImageMap mode? In such case you can change items' appearance only on the server side, so it won't be possible to set the link's pen from the Enter and Leave handlers. You will have to use Java mode for that.
rlira
Reply #2 - Jul 18th, 2011 at 5:00pm
Hello!
Yes, I am using ImageMap mode. I tried changing to JavaApplet mode but I get the following:
java.lang.ClassFormatError: Incompatible magic value 218762506 in class file com/mindfusion/diagramming/DiagramApplet
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Exceção: java.lang.ClassFormatError: Incompatible magic value 218762506 in class file com/mindfusion/diagramming/DiagramApplet
JDiagram.jar is located at page's folder (I tried setting is programatically but I got the same error) and all references are set.
Any idea on what could be happening?
Again, thanks for helping.
Reply #3 - Jul 18th, 2011 at 5:10pm
Hi!
This usually happens when using Forms Authentication; then the server returns some kind of response that the Java plugin cannot recognize.
One work-around is moving the jar file to unprotected area of your site (last discussed here http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=131074561...).
Another option is preloading the applet (e.g. a hidden copy) from your login form. If you preload the applet, the browser will have it in the cache and won't try to load it again from the protected pages.
rlira
Reply #4 - Jul 18th, 2011 at 5:41pm
Thank you for your support.
Browser was able to load the applet once I put the JAR file into an unprotected folder.
But yet I can't highlight the link OnMouseOver.
The parameter for setColor should be a Color class.
After looking at java documentation, I tried:
args.getLink().getPen().setColor(new Color(255,0,0));
args.getLink().getPen().getColor().setRed(255);
and finally
args.getLink().getPen().setColor(new java.awt.Color(255,0,0));
The latter won't raise an exception. However the link does not get displayed as red.
I appreciate any help.
Thanks.
Reply #5 - Jul 18th, 2011 at 6:04pm
You will have to call setPen for the diagram to repaint automatically, and also you cannot create new Java objects from JavaScript (unless the classes are somewhere in the CLASS_PATH) so you will have to use the create* methods in ScriptHelper:
var applet = <%= diagramView.AppletElement %>;
var pen = applet.getScriptHelper().createPen(width, r, g, b);
args.getLink().setPen(pen);
