Normal Topic how to add process activity in if-else condition (Read 3789 times)
deepak
Jul 16th, 2011 at 7:05am
I referred workflowdesigner. But I want to add Process in the diagramview from listbox. When I add the process automatically generate if-else nodes in diagramview. In if-else condition I want to add processes. I can also add the if-else, which conditions multiple times in digramview in between the above true & false conditions.
Please tell me there is any other option.
Re: how to add process activity in if-else conditi
Reply #1 - Jul 16th, 2011 at 7:50am
If you are you trying to add new kind of workflow elements that are laid out the same way as "Activity" nodes are, set LayoutTraits[WorkflowItemId] = "Activity" when creating a node from their listbox item.
deepak
Reply #2 - Jul 16th, 2011 at 10:29am
Please give me the steps to create the new node in listbox.
In this node I want to add the
1.  Process
2.  After adding process add If-else condition
3.  In if part & else part again new Process is
     inserted.
4.  I drag new condition from the listbox & drop on
     after new Process.
& How to attached the image or file in this blog.
Reply #3 - Jul 18th, 2011 at 6:08am
Do you mean you need a listbox item that creates several nodes and links with a single drag-and-drop operation?
You can't upload images here. You could add a link to one  on your server or some image hosting site, or email it to support@mindfusion.eu.
deepak
Reply #4 - Jul 18th, 2011 at 8:34am
Yes. I want to create a new item in listbox. In this item I want to add activity, then If-else & under if-else again activity.
deepak
Reply #5 - Jul 18th, 2011 at 10:37am
How to set the last node destination point as new node origin point.
Reply #6 - Jul 18th, 2011 at 11:14am
I think this method does what you described:
private void CreateProcess(DiagramLink link)
	CreateActivity(link);
	DiagramLink lastLink = diagram.Links[diagram.Links.Count - 1];
	CreateIfElse(lastLink);
	CreateActivity(lastLink);
Call it from the switch statement in view_DragDrop:
case "Process":
	CreateProcess(link);
	break;
deepak
Reply #7 - Jul 18th, 2011 at 5:21pm
I used the code which you have provided but i am not gettig correct sequence. i need to following sq.
1. Activity
2. under activity If-Else needs to be add &
in If -Else under add activity in ture & false condition
3. flow needs to be complate
When I drag Process(item) from listbox, I need to create a nodes like following diagram.
                   |  Process1 = 1      |
                   |  Process2 = 0      |
                 1          |          0
               (True)       |       (False)
         | Process1 = 1 |       | Process2 = 0 |
                  ----------O-----------
« Last Edit: Jul 19th, 2011 at 5:38am by deepak »
Reply #8 - Jul 19th, 2011 at 1:27pm
	DiagramLink trueLink = diagram.Links[diagram.Links.Count - 3];
	DiagramLink falseLink = diagram.Links[diagram.Links.Count - 2];
	CreateActivity(trueLink);
	CreateActivity(falseLink);
Even better, change the various Create methods to return some objects describing the just created workflow elements. For example CreateIfElse could return an object with TrueLink and FalseLink properties that give you direct references to the links, so you don't have to rely on the links order within the collection.
