Normal Topic EnterInplaceEdit and LeaveInPlaceEdit events (Read 1555 times)
rajesh_patil74
Jul 19th, 2011 at 11:44am
Hi Stoyo
In my application, I want to cancel the EnterInPlaceEdit event based on some conditions.
It seems it is not possible.
Also, when LeaveInPlaceEdit event is fired, I am not able to get whether it is fired due to cancel or enter event ( i.e EndEdit(true) or EndEdit(false) caused it) - ( For this I need to compair old value of node/link with new value but it would be nice if that accept/cancel operation is available thro event argument )
-Rajesh
Re: EnterInplaceEdit and LeaveInPlaceEdit events
Reply #1 - Jul 19th, 2011 at 12:01pm
Hi Rajesh,
You can disable AllowInplaceEdit and explicitly call Diagram.BeginEdit from the NodeDoubleClicked handler only if the node meets these conditions. Handle NodeTextEdited to find out if the node text has changed.
