Normal Topic Drag-n-Drop into Container Node (Read 1971 times)
Turtlebase
Jul 19th, 2011 at 4:40pm
I new to the Diagram Control and I would like to have a simple way to drag an item from a list box and drop it inside an existing container node. I have no probelms with draging and droping items from the list box into the diagram but when I try to drop the item inside a container node it is placed under the container node.  I'm sure that there is some simple way to have the drop place the new item in the container node.
Thank you, Advice?
Re: Drag-n-Drop into Container Node
Reply #1 - Jul 19th, 2011 at 5:49pm
Are you calling ContainerNode.Add after creating the new node? You can use the Diagram.GetNodesAt method to get all nodes at the mouse position. Find the ContainerNode from the returned list that has highest ZIndex and add the new node to it.
turtlebase
Reply #2 - Jul 21st, 2011 at 5:38pm
Thank You, I used the getNodesAt on the drag event to see what kind of node is was and if it was a container node returned it.  Worked fine, Whats the best way to resize the container after the drop? right now it gets real big after the drop!
Reply #3 - Jul 21st, 2011 at 6:06pm
Call the container's UpdateBounds method, or if you set AutoShrink = true, it should get called automatically.
