Normal Topic Autonumber, or display the tags (Read 2159 times)
jagdipa
Jul 22nd, 2011 at 10:50am
I would like to autonumber the shapes that are being added to the diagram (using the java applet).
So, for example, I would like the first shape to be 1, and its children to be 1.1, 1.2, 1.3, and their children to be 1.1.1, 1.1.2, 1.2.1, etc.
I am trying to get this numbering sorted and saved in the Tag property. I was just wondering whether there is an easy way to display this Tag property. I would like it displayed in the upper left corner, outside the shape.
Re: Autonumber, or display the tags
Reply #1 - Jul 22nd, 2011 at 12:54pm
You could set the node's CustomDraw property to Additional and set this function as DrawNodeScript:
function onDrawNode(sender, args)
	var applet = <%= diagramView.AppletElement %>;
	var diagram = applet.getDiagram();
	var helper = applet.getScriptHelper();
	var node = args.getNode();
	var gfx = args.getGraphics();
	var rect = node.getBounds();
	var black = helper.createSolidBrush(0,0,0);
	var format = helper.createTextFormat(0,0,false,false);
	diagram.drawString(node.getTag(), gfx, node.getFont(), black, rect, format);
I'm not sure how fast it will be to draw from JavaScript though. You might be better of using attached nodes to display the Tag value of other nodes. If you set Transparent = true for the attached nodes, only their text remains visible.
jagdipa
Reply #2 - Aug 1st, 2011 at 1:05pm
Hi stoyo,
would creating a transparent shape work, even when I have a Tree Layout?
For example, I am trying to use the following code which doesnt do what I am looking for.
Also, would the transparent shape have the correct layout when I add more shapes - i.e. will the shape move along with its relevant node?
	  function addNodeLabel(node, text) {
		var label = diagram.getFactory().createShapeNode(node.getBounds().getX(),
				node.getBounds().getY(),
				node.getBounds().getWidth(),
				4);
		label.setBrush(script.createSolidBrush(0, 0, 0));
		label.setText('This is a test');
		var group = node.getSubordinateGroup();
		if (group == null) {
		alert('creating group');
		    group = diagram.getFactory().createGroup(node);
		group.attachToCorner(label, 3);
Reply #3 - Aug 1st, 2011 at 1:55pm
I've modified your code to attach a transparent 'label' at the top of the specified node, lock the label and set its IgnoreLayout to false to ensure that the label won't be modified by subsequent automatic layouts and that it will retain its position relative to its master node.
      node.getBounds().getY() - 4,
      4);
label.setTransparent(true);
label.setText(text);
label.setIgnoreLayout(true);
label.setLocked(true);
if (group == null)
group.attachToCorner(label, 0);
I hope this helps.
