Normal Topic DiagramLink (Read 1963 times)
Tima
DiagramLink
Jul 25th, 2011 at 8:58am
I need to Create a link Between Two node in a way that It start From Right Side of First Node and end into left side of right node .. its only possible when the node are in series...If first node is in right side and second one in left side from first, then it starting from left of first and end to right of second node i want above one..
What should i use to get this..?
Re: DiagramLink
Reply #1 - Jul 25th, 2011 at 10:58am
Check this out. The same technique can be used in JDiagram.
