Normal Topic spacing in tree layout (Read 4867 times)
mikemitri
Jul 28th, 2011 at 11:38pm
Hi. I have an issue with tree layouts when there are lots of nodes (in the 80s for example). Often the result is that nodes are spaced quite far apart from each other, leaving lots of blank space in the diagram.
The code for setting up the layout is like this:
Dim tl As New TreeLayout()
tl.Direction = TreeLayoutDirections.TopToBottom
tl.LinkStyle = TreeLayoutLinkType.Cascading3
tl.Type = TreeLayoutType.Centered
tl.Root = rootDiagramNode
tl.IgnoreLinkDirection = True
tl.LevelDistance = 10
tl.NodeDistance = 5
I guess I could do the layout and then re-position items in my code, but this seems pretty cumbersome.
Here is the image:
[img]http://legacyforward.com/treelayout.jpg[/img]
Thanks for your help!
Re: spacing in tree layout
Reply #1 - Jul 29th, 2011 at 7:06am
This layout does not look alright. Are you sure the diagram being arranged is indeed a tree? Looking at the image some nodes appear to have more than one parent, and the TreeLayout is meant to operate only on tree structures. If it is a tree, could you save this diagram and send it to me to support@mindfusion.eu?
mikemitri
Reply #2 - Jul 30th, 2011 at 5:00pm
It is true that there are cycles in the graph, so it is not a true tree. I do specify a root node for the layout, as you can see in the code. Are you saying that the TreeLayout can't be made to work for cyclic graphs? Actually I do get something tree-like (i.e. hierarchical) appearing, and it generally works ok for me, but as I said the spacing is often unwieldy. Any ideas of how to alleviate the spacing in situations where nodes can have more than one incoming link?
Reply #3 - Jul 30th, 2011 at 5:33pm
The TreeLayout is guaranteed to operate properly only on strict tree structures. You can try to analyze your graph and set IgnoreLayout to false for all links which cause loops. Then manually position these links after the layout has run.
An alternative would be to use one of the other layout algorithms, such as LayeredLayout or OrthogoonalLayout.
Let me know if this helps.
mikemitri
Reply #4 - Aug 1st, 2011 at 1:57pm
Ah. I understand. Thanks for the explanation. Nevertheless, the tree does seem to work pretty well as a layout, even when there are a few cycles in the graph. And it has the advantage of showing the designated root node at the top of the hierarchy, and giving a hierarchical arrangement of nodes. It's just that it results in a lot of wasted space on the display. Would you have any suggestions on how to resolve this? Does it require, as I had speculated earlier, that I programmatically shift positions of individual nodes after the layout has been applied? Or are there any TreeLayout properties I could set or methods I could call to address the spacing issues within the layout algorithm itself?
Reply #5 - Aug 1st, 2011 at 2:16pm
Can you save your diagram (preferably in XML) and send it to meppy@mindfusion.eu? I will check if I can improve the resulting layout.
Reply #6 - Aug 2nd, 2011 at 7:20am
Try the following solution.
1. Define a function, which creates a spanning tree from a source diagram by setting IgnoreLayout of some of the links to true. The function accept as arguments the source diagram and the node that should be used as root, and returns a list with all ignored links.
Private Shared Function MakeTree(ByVal diagram As Diagram, ByVal root As DiagramNode) As List(Of DiagramLink)
      Dim ignoredLinks As New List(Of DiagramLink)()
      Dim visited As New Dictionary(Of DiagramNode, DiagramNode)()
      Dim visitedLinks As New Dictionary(Of DiagramLink, DiagramLink)()
      Dim remaining As New Queue(Of DiagramNode)()
      visited.Add(root, root)
      remaining.Enqueue(root)
      root.Tag = 0
      While (remaining.Count > 0)
            Dim [next] = remaining.Dequeue()
            Dim allLinks As New List(Of DiagramLink)()
            For Each link As DiagramLink In [next].OutgoingLinks
                  allLinks.Add(link)
            Next link
            For Each link As DiagramLink In [next].IncomingLinks
                  allLinks.Add(link)
            Next link
            For Each link As DiagramLink In allLinks
                  If (visitedLinks.ContainsKey(link)) Then
                        Continue For
                  End If
                  Dim destination = IIf(link.Destination Is [next], link.Origin, link.Destination)
                  If (visited.ContainsKey(destination)) Then
                        link.IgnoreLayout = True
                        ignoredLinks.Add(link)
                        Continue For
                  End If
                  visited.Add(destination, destination)
                  visitedLinks.Add(link, link)
                  remaining.Enqueue(destination)
                  Dim origin = [next]
                  destination.Tag = CInt(origin.Tag) + 1
            Next link
      End While
      Return ignoredLinks
End Function
2. Perform the layout on the diagram. The links with IgnoreLayout = true will automatically be ignored. After the layout has run, manually set the points of the ignored links.
Public Sub LayoutTree(ByVal diagram As Diagram, ByVal root As DiagramNode)
      If (diagram.Nodes.Count = 0) Then
            Return
      End If
      Dim ignoredLinks = MakeTree(diagram, root)
      Dim l As New TreeLayout()
      l.Root = root
      l.NodeDistance = 5
      l.Arrange(diagram)
      ' Manually arrange the ignored links
      For Each link As DiagramLink In ignoredLinks
            Dim origin As DiagramNode = Nothing
            Dim destination As DiagramNode = Nothing
            If (CInt(link.Origin.Tag) < CInt(link.Destination.Tag)) Then
                  origin = link.Origin
                  destination = link.Destination
            Else
                  destination = link.Origin
                  origin = link.Destination
            End If
            Dim originBounds = origin.Bounds
            Dim destinationBounds = destination.Bounds
            Dim distance = destinationBounds.Top - originBounds.Bottom
            link.SegmentCount = 3
            link.ControlPoints(0) = New PointF(originBounds.Left + originBounds.Width / 2, originBounds.Bottom)
            link.ControlPoints(1) = New PointF(originBounds.Left + originBounds.Width / 2, originBounds.Bottom + distance / 2)
            link.ControlPoints(2) = New PointF(destinationBounds.Left + destinationBounds.Width / 2, destinationBounds.Top - distance / 2)
            link.ControlPoints(3) = New PointF(destinationBounds.Left + destinationBounds.Width / 2, destinationBounds.Top)
            link.UpdateFromPoints()
      Next link
End Sub
mikemitri
Reply #7 - Aug 2nd, 2011 at 12:45pm
Thanks. I'll try that and let you know how it goes.
mikemitri
Reply #8 - Aug 6th, 2011 at 2:02pm
Thanks Meppy, that worked well. I set the links of the cycle (detected in your MakeTree function) to ignoreLayout and also Visible=false, and it makes a big improvement in the displayed tree. Thanks!
