Normal Topic Set Tag for Shapes (Read 2622 times)
SL_developer
coding rocks
Set Tag for Shapes
Aug 1st, 2011 at 6:34am
Hi
In my application all shapes are created on the basis of ShapeId's
 const double size = 50;
 double x = 0;
 double y = 0;
 int shapesPerRow = 1;
  foreach (string shapeId in Shape.Shapes.Keys)
		  var node = diagram.Factory.CreateShapeNode(x, y, 50, 50);
		    node.Shape = Shape.Shapes[shapeId];
		    x += size + 4;
		    if (x > (shapesPerRow - 1) * (size + 5))
			  y += size + 4;
			  x = 0;
		    node.Locked = true;
How to set Tag for each shape node in above code, tag like "Rectangle","Decision","Process" for respective shapes?
Re: Set Tag for Shapes
Reply #1 - Aug 1st, 2011 at 10:58am
I'm not entirely sure what you want to achieve. If you simply want to assign the shape identifier to the node's tag, you can do it like this:
node.Tag = shapeId;
SL_developer
coding rocks
Reply #2 - Aug 1st, 2011 at 11:15am
Hi
Thanks for reply,
i have added this line of code but still tag is not displaying
I refered this sample
https://mindfusion.eu/_samples/_sample_DragDrop3.zip
in this sample I have to display tag, please tell me how to do that?
Reply #3 - Aug 1st, 2011 at 11:57am
If you need to display the shape id, set it to the node's Text property:
node.Text = shapeId;
The alignment of the text within the node can be specified through the TextAlignment, HorizontalTextBlockAlignment and VerticalTextBlockAlignment properties.
