Normal Topic springLayout in 3D put all nodes in the same locat (Read 2364 times)
Hamdy Ghanem
Aug 1st, 2011 at 8:54am
I am working with 3D
I am using this line
springLayout.Iterate(currentIteration, ++currentIteration)
the springLayout ill put all the nodes in the same position
what I did wrong?
Re: springLayout in 3D put all nodes in the same l
Reply #1 - Aug 1st, 2011 at 11:14am
Are you looking at the SpringLayout sample?
As you can see there, you have to invoke DiagramView3D.ResetProjection method after each iteration to update the view with the new positions of the nodes? In addition, make sure you have called SpringLayout.BeginArrange before making any calls to SpringLayout.Iterate.
Hamdy Ghanem
Reply #2 - Aug 1st, 2011 at 11:15am
Yes I did all of that m but still all ones in the center
Hamdy Ghanem
Reply #3 - Aug 1st, 2011 at 11:16am
  springLayout.BeginArrange(CurrentDiag3D, Nothing)
then
Private Sub timer_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles timer.Tick
       CurrentDiagView3D.ResetProjection()
    End Sub
Reply #4 - Aug 1st, 2011 at 11:48am
Is it possible to send me your application (or a smaller sample illustrating this problem) to meppy@mindfusion.eu?
Hamdy Ghanem
Reply #5 - Aug 1st, 2011 at 1:16pm
it is working now
I miss the links
Thanks for ur help
