Normal Topic Scheduling Reminder (Read 2925 times)
Karl
Scheduling Reminder
Aug 1st, 2011 at 12:57pm
When I want to set the TimeInterval programatically it is restricted to MaxInterval. The current value of this property is 2 days. But I need to set a bigger interval. Is there a way to change it?
Re: Scheduling Reminder
Reply #1 - Aug 1st, 2011 at 1:30pm
There is currently no simple way to work around this limitation, unless you are in possession of the source code.
Looking at the source code this limitation exists only to prevent the generation of large sets of recurring items when checking for a reminder in a specific time interval. We may be able to lift this restriction if this is important for your project.
