Normal Topic fix text bounds (Read 2961 times)
superNova
fix text bounds
Aug 5th, 2011 at 6:08am
when we add text onto shapnode its come in center by default is there anyway to fix this text at particular place on shapnode.
Re: fix text bounds
Reply #1 - Aug 5th, 2011 at 6:59am
You have to apply a TextFormat object with the appropriate values to the node via the setTextFormat method.
superNova
Re: fix text bounds
Reply #2 - Aug 6th, 2011 at 5:09am
its not accepting int value. pls provide suitable example like shapnode1.settextformat (  ??)
what parameter i should pass here.
Re: fix text bounds
Reply #3 - Aug 7th, 2011 at 7:36am
The following code applies a bottom-left text alignment to the ShapeNode referenced by the variable node:
node.getTextFormat().setHorizontalAlign(Align.Near);
node.getTextFormat().setVerticalAlign(Align.Far);
Alternatively, you can create a new TextFormat object, set its values and assign it to the node through the setTextFormat method.
