Normal Topic Diagram is not editable but can select shape ? (Read 4676 times)
Anjana
Aug 10th, 2011 at 6:17am
Hi Stoyo
1)diagram view is not editable(using mouse anybody can draw a flowchart it is not possible how to do)  and flowchart diagram also is also not editable(like size of shape is fixed,not move shapes) but can select ashape.
bottom point is  flowchart is only see by user can select perticuler shape but cant edit diagram and cant draw shape  using mouse in   diagramview
Its urgent...
please help me
Anjana
Re: Diagram is not editable but can select shape ?
Reply #1 - Aug 10th, 2011 at 7:45am
If you are using the ImageMap client-side mode and you want users to be able to create new and modify existing items interactively, you have to add an InteractivityExtender to your project. Check out the Interactivity sample for more information on how to do it.
Anjana
Reply #2 - Aug 12th, 2011 at 4:58am
flowchart is only see by user and can select perticuler shape but cant edit diagram and cant draw shape  using mouse in   diagramview
Reply #3 - Aug 12th, 2011 at 7:03am
Do you want users to be able to edit the diagram - to draw shapes and links with the mouse?
If this is the case, add an InteractivtyExtender object (found in the mindfusion.extenders.dll assembly) to the page containing the diagram. Then set the TargetControlID property of the InteractivityExtender object to the ID of the DiagramView.
Anjana
Reply #4 - Aug 12th, 2011 at 7:46am
Thanks for reply ....
i dont allow user cant edit Flowchart and cant draw shape using mouse after displying Flowcahrt in diagramview .but can select shpae.
here i am giving linking to next flowchart using shape that time he has to select shape.
Reply #5 - Aug 12th, 2011 at 9:42am
Which client-side mode are you using? If you want to prevent users from modifying the diagram, you have to use different approach depending on the client-side mode.
