Hot Topic (More than 10 Replies) snap to on drag/drop (Read 6710 times)
DoctorsDad
Aug 10th, 2011 at 3:59pm
I've set snapUnitCCount in my ResourceViewSettings and if I move an existing appointment, it dutifully snaps to the time I specified. But when I drag/drop an item onto the Calendar it lands on any old time.
Is there a simple way for me to force these events to follow the same rule?
TIA,
Dave
Re: snap to on drag/drop
Reply #1 - Aug 11th, 2011 at 6:26am
Currently you can do this only by manually calculating the nearest snap time. I will see if we can add a method, which performs this calculation automatically.
DoctorsDad
Reply #2 - Aug 11th, 2011 at 12:28pm
Many thanks,
I don't want to be a pain but can you give me an idea of timescale? I need to know if I should press on or wait a while.
Dave.
Reply #3 - Aug 11th, 2011 at 1:53pm
Check this version of the control:
https://mindfusion.eu/download/MindFusion.Scheduling.5.2.0a.trial.zip
The Calendar class now exposes a new method - SnapInResourceView(DateTime), which performs programmatic snapping of the specified date taking into consideration the current Resource View settings.
If it works well, contact me at meppy@mindfusion.eu for a licensed version.
DoctorsDad
Reply #4 - Aug 11th, 2011 at 4:14pm
Many thanks Meppy.
I'm not sure if I've guessed how to use this correctly.
I'm doing this:
Dim app As New MindFusion.Scheduling.Appointment()
app.StartTime = Calendar1.SnapInResourceView(currentCellDateTime)
but it's not achieving much.
Am I doing it wrong?
Dave.
Reply #5 - Aug 12th, 2011 at 6:02am
This is how it should be used. What is it that doesn't work, does it return the same date?
DoctorsDad
Reply #6 - Aug 12th, 2011 at 8:59am
Yep, time after is exactly the same as time before call.
Reply #7 - Aug 12th, 2011 at 9:44am
Can you provide me with your resource view settings, the snap settings more specifically?
DoctorsDad
Reply #8 - Aug 12th, 2011 at 9:48am
I've set SnapUnitCount to 15 and SnapUnit to Minute
Reply #9 - Aug 12th, 2011 at 11:43am
Try this version:
https://mindfusion.eu/download/MindFusion.Scheduling.5.2.0b.trial.zip
I haven't tested it much, so I appreciate any feedback.
DoctorsDad
Reply #10 - Aug 12th, 2011 at 2:17pm
Sorted!
Many thanks.
Dave.
