Normal Topic [SOLVED] KeepGroupLayout (Read 3738 times)
Carlos_Rocha
I love Jazz
Aug 12th, 2011 at 3:14am
It seems KeepGroupLayout=true does nothing, and grouped boxes are splited after applying a TreeLayout.
The boxes are grouped like in VB sample "NetSample", with a picture and a label.
Only the pictures are connected to each other using CreateArrow method, programatically.
Am I missing something?
Carlos
« Last Edit: Aug 12th, 2011 at 12:22pm by Carlos_Rocha »
Re: KeepGroupLayout
Reply #1 - Aug 12th, 2011 at 6:31am
KeepGroupLayout should behave exactly as you described - make the layout interpret the grouped objects as one big node and keep their relative positioning. What FlowChartX version are you using?
Can you also try setting IgnoreLayout to true for the label nodes and see if they are being misplaced again?
Carlos_Rocha
I love Jazz
Re: KeepGroupLayout
Reply #2 - Aug 12th, 2011 at 12:21pm
The version is 4.4.0.0, from 2011-03-24, and
making IgnoreLayout=true for the labels it works as expected, thank you.
Re: [SOLVED] KeepGroupLayout
Reply #3 - Aug 12th, 2011 at 1:21pm
If it is possible, save your diagram and e-mail it to me at meppy@mindfusion.eu? I would like to have a look at it.
Carlos_Rocha
I love Jazz
Reply #4 - Aug 12th, 2011 at 3:33pm
I don't have a diagram yet, I'm still studying how to apply automatic layouts. I'll try to prepare a case study.
