Normal Topic Change Mouse Pointer (Read 1682 times)
SL_developer
coding rocks
Aug 12th, 2011 at 12:56pm
Hi
Is there any way to change the mouse pointer of diagram to selection mode & Draw mode ?
[ If Selection Mode then user can only select all node by dragging mouse pointer or selection by clicking on nodes.
If Draw mode then only draw a diagram with default behaviour. ]
Re: Change Mouse Pointer
Reply #1 - Aug 12th, 2011 at 2:28pm
To implement a select-only behavior in the Diagram, follow these steps:
Create a custom behavior class:
private class SelectBehavior : BehaviorBase
      public SelectBehavior(Diagram diagram)
            : base(diagram)
      protected override bool OnMouseDown(MouseButtonEventArgs e)
            return base.OnMouseDown(e);
      public override Cursor SetMouseCursor(Point point, out bool startInteraction)
            startInteraction = false;
            return Cursors.Arrow;
      public override InteractionState StartDraw(Point point)
            return new InteractionState(Diagram.Selection, Action.Create, -1, point);
Assign an instance of this class as behavior of the diagram:
diagram.CustomBehavior = new SelectBehavior(diagram);
diagram.Behavior = Behavior.Custom;
Finally handle the SelectionMoving, NodeModifying and LinkModifying events and cancel dragging in each of them:
e.CancelDrag();
Now you can switch back and forth between the default diagram behavior and the newly implemented behavior.
