Normal Topic shape of shape node (Read 2064 times)
vchimakurthi
shape of shape node
Aug 15th, 2011 at 3:02pm
hi
how can i change the shape of shape node to any image file
i set
image is inserted in side the node.. we dont want predefined shapes
thanks
Re: shape of shape node
Reply #1 - Aug 15th, 2011 at 3:10pm
Set ShapeNode.Transparent = true to hide the shape. Only the image and text will be displayed then.
vchimakurthi
Reply #2 - Aug 16th, 2011 at 8:36am
hi i set the image attach a label to it .
its not attaching label at the bottom.
childNode.Image = imageList1.Images[index];
           childNode.Text = "";
           childNode.Transparent = true;
           ShapeNode label = diagram.Factory.CreateShapeNode(0, childNode.Bounds.Bottom, 10, 7);
           label.AttachTo(childNode, AttachToNode.BottomCenter);
           label.Text = name;
           label.TextFormat.LineAlignment = StringAlignment.Center;
           label.Transparent = true;
           label.Locked = true;
Reply #3 - Aug 16th, 2011 at 8:45am
AttachTo does not align the attached node to its master node, but just records their initial offset and preserves it when you move the master. So you will have to specify both the x and y coordinates relatively to the node:
CreateShapeNode(childNode.Bounds.Left, childNode.Bounds.Bottom, childNode.Bounds.Width, 7);
In case you are running some layout algorithm after that, enable the KeepGroupLayout property of the layout class, so that it does not move the labels away.
