Normal Topic Diagramview 3D auto rotate (Read 2502 times)
Hamdy Ghanem
Aug 17th, 2011 at 2:06pm
I want to auto rotate the view viewing
I add a code to change CameraPosition in a timer but it did not work
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
       ' dgView3D.CameraRotation = New Point3D(dgView3D.CameraRotation.X, dgView3D.CameraRotation.Y + 5, dgView3D.CameraRotation.Z)
       With dgView3D.CameraPosition
           Dim angleInPie As Double = _CurrentAngle * (Math.PI / 180)
           Dim sinOfAngle As Double = Math.Sin(angleInPie)
           Dim cosOfAngle As Double = Math.Cos(angleInPie)
           Dim nextX As Single = .X * cosOfAngle - .Y * sinOfAngle
           Dim nextY As Single = .Y * sinOfAngle + .Y * cosOfAngle
           Dim nextZ As Single = .Z
           dgView3D.CameraPosition = New Point3D(nextX, nextY, nextZ)
           _CurrentAngle += 1
           If _CurrentAngle > 360 Then
               _CurrentAngle = 0
           End If
           dgView3D.ResetProjection()
       End With
    End Sub
Hamdy Ghanem
Re: Diagramview 3D auto rotate
Reply #1 - Aug 17th, 2011 at 2:14pm
another question plz: with ctrl key why it is not rotating in center I feel it is taking some angle
Reply #2 - Aug 18th, 2011 at 4:59am
I can't make any sense of your X and Y assignments. If you need the camera to move in a circle around some point in a fixed Z plane, use this formula:
nextX = point.X + radius * Math.Cos(angle);
nextY = point.Y + radius * Math.Sin(angle);
Then you can call the PointCameraTo method to point the camera to the center point.
Hamdy Ghanem
Reply #3 - Aug 20th, 2011 at 8:29am
what is the radus ?
Reply #4 - Aug 22nd, 2011 at 5:55am
It should be the distance from the camera to the rotation center, assuming you want the camera to move around that point. If you need the camera to stay in the same location but just change its orientation, you should only increment the CameraRotation angles.
