Hot Topic (More than 10 Replies) Anchor pattern changes while loading (Read 9245 times)
SL_developer
coding rocks
Aug 18th, 2011 at 4:38am
while loading the saved diagram , anchor behavior change to normal position.
As I applied anchor pattern also but its not showing the same while loading it from file.
Re: Anchor pattern changes while loading
Reply #1 - Aug 18th, 2011 at 5:29am
What do you mean by "change to normal position"? If you are using custom AnchorPattern objects and they are not loaded, make sure you create them with the constructor that takes an id argument. AnchorPatterns are saved only by id, and you should have them already defined when  loading the diagram file next time.
SL_developer
coding rocks
Reply #2 - Aug 18th, 2011 at 1:11pm
"Change to normal position" means Link Cascading style is not shown.
 diagram.LinkStyle = LinkStyle.Cascading;
 diagram.LinkSegments = 3;
like this I am creating linkstyle, and
loading diagram in this way :
 diagram.LoadFromString(xml);
Now tell me what I need to do?
Reply #3 - Aug 18th, 2011 at 2:56pm
Do you mean that loading a file changes the LinkStyle property to Polyline? LinkStyle is saved too when you call SaveToXml, so if you load an older file created before you started using Cascading links, LinkStyle will revert to Polyline. In such case, you will have to reset the property to Cascading after calling LoadFromXml.
SL_developer
coding rocks
Reply #4 - Sep 7th, 2011 at 9:54am
Hi
How to reset the property to Cascading after calling LoadFromXml ?
Reply #5 - Sep 7th, 2011 at 9:59am
Like this:
Diagram.LinkStyle is a default value for new links. If you need to change the style of existing links after loading a file, you will have to loop over them:
foreach (DiagramLink link in diagram.Links)
	link.Style = LinkStyle.Cascading;
SL_developer
coding rocks
Reply #6 - Sep 8th, 2011 at 4:51am
I really dont know where I am wrong but still its not working for me
This is how I am doing in my application
Diagram.RegisterItemClass(typeof(ChartNode), "classNodeId", 1);
string xml = e.Result; //e.result is coming from DB
 if (xml.Length > 0)
 ddtarget.LoadFromString(xml);
 ddtarget.LinkStyle = LinkStyle.Cascading;
 ddtarget.LinkSegments = 3;
Can you please provide one sample zip code for this where we save & load for same Link style?
Reply #7 - Sep 8th, 2011 at 10:17am
Could you explain more clearly what the problem is? Are you saying that the loaded links don't have the same link.Style as when they were saved?
SL_developer
coding rocks
Reply #8 - Sep 8th, 2011 at 11:00am
Yes, when I save the diagram Link style is Cascading
but if it loads from DB then Link style change
Reply #9 - Sep 8th, 2011 at 11:20am
Could you email the saved xml file to support@mindfusion.eu?
SL_developer
coding rocks
Reply #10 - Sep 8th, 2011 at 12:14pm
I have send you an email with xml file please check & let me know
Reply #11 - Sep 8th, 2011 at 3:15pm
This is what we got:
Does it look different from what you saved in the file? The links shapes correspond exactly to the point coordinates that are saved in the file. It seems you are using a custom node type registered as "classNodeId", which our developer replaced with ShapeNodes in order to load the file. Does your custom type override the CreateConnectionPoint method by any chance?
SL_developer
coding rocks
Reply #12 - Sep 9th, 2011 at 5:02am
Hi
Yes diagram looks same.
My custom class not overriding CreateConnectionPoint method. Please tell me how to use it.
Also If I remove my custom class then with shapeNode what I need to do?
Thanks for Support 8)
Reply #13 - Sep 9th, 2011 at 6:52am
Check your code then, there should be some assignments to the links' Style or ControlPoints that change them to straight lines after calling LoadFromXml. If you think the problem is in LoadFromXml, try to reproduce it in a test project and email it to us for our developer to investigate.
