Normal Topic Routing links (Read 2325 times)
Amosius
Routing links
Aug 18th, 2011 at 9:57am
i am using link.route()
I would like to use several routingoptions so i tried
                diagram.LinkRouter = new GridRouter();
                diagram.RoutingOptions.TurnCost = 100;
                diagram.RoutingOptions.CrossingCost = 50;
                diagram.RoutingOptions.LengthCost = 20;
                diagram.RoutingOptions.NodeVicinityCost = 30;
                diagram.RoutingOptions.NodeVicinitySize = 20;
                diagram.RoutingOptions.StartOrientation = MindFusion.Diagramming.Wpf.Orientation.Horizontal;
and then i would like to route a link with link.route()
But i can change all cost values, it does not effect my route.
There are two possibilities to call routing:
bool routing1 = diagram.LinkRouter.RouteLink(link);
bool routing2 = link.Route();
routing1 is false while routing2 is true.
I am a little bit confused. Does link.route() not take my routingoptions?
Amosius
Re: Routing links
Reply #1 - Aug 18th, 2011 at 3:08pm
The values will affect your route only if they lead to finding a new minimal cost path, which might not happen for short links. You could check this in the Routing sample project - draw a few longer links, drag the sliders and click Reroute - this shows different paths for me.
Amosius
Re: Routing links
Reply #2 - Aug 19th, 2011 at 12:00pm
I reduced cost values and now i can influence routing.
I will experiment now a little bit. Thx for your help.
Amosius
