Normal Topic A question about print (Read 1753 times)
CanadaProgrammer
Sep 13th, 2011 at 3:40am
I print a diagram but the bound of node is dash line on paper. I think it should be bold line. I can save a diagram as a JPEG file. I think what print outputs should be what JPEG file shows.
By the way I set MeasureUnit property to Display.
Re: A question about print
Reply #1 - Sep 13th, 2011 at 6:01am
Are you printing in black and white? Then you might see white pixels on the node border if it's in a different color than black, because the printer uses some patterns of pixels to represent the different colors.
If you print in color, the result should be no different than what you see on the screen. The DiagramItem.Draw method is called both when printing and drawing on screen (also in the Overview control and in exported images), and it always draws border lines using the item's Pen value.
CanadaProgrammer
Reply #2 - Sep 14th, 2011 at 1:49am
Yes, it is helpful. Thanks !
