Normal Topic Hide weekends in SingleMonth view (Read 3323 times)
JeanLouisFromParis
Sep 15th, 2011 at 8:43am
Is there a way of hiding the weekends while in SingleMonth view?
Re: Hide weekends in SingleMonth view
Reply #1 - Sep 15th, 2011 at 9:58am
Unfortunately, there is currently no such feature. The only view supporting limited date/time filtering is the Resource view.
JeanLouisFromParis
Reply #2 - Sep 15th, 2011 at 10:34am
Thanks for your quick reply.
Are there any plans to add such a feature in the future?
And, by using custom drawing handlers, is it possible to reduce the size of the columns for Saturdays and Sundays?
Thank you!
Reply #3 - Sep 15th, 2011 at 10:48am
We can try implementing this feature but I have suspicions it might not be trivial. We will check this and I will get back to you with an answer as soon as possible.
As for the second question - custom drawing cannot be used to change the layout of the component (that is, it cannot resize or collapse elements, and so on). Custom drawing is invoked on elements with predetermined sizes in order to draw on top of the default visualization.
Reply #4 - Sep 16th, 2011 at 1:09pm
A new version of the control can be downloaded from the link below:
https://mindfusion.eu/_downloads/MindFusion.Scheduling.Trial.zip
There is a new property - Calendar.MonthSettings.FilterWeekends, which when set to Enabled, will hide weekends in SingleMonth and MonthRange views.
The new feature has not been thoroughly tested. If you come across any issues, be sure to let me know.
