Normal Topic Moving camera 3D (Read 2777 times)
Hamdy Ghanem
Moving camera 3D
Sep 21st, 2011 at 8:31am
I have a 3D diagram
I it is spring layout ( one node in the middle and others are related )
I want the centered node to look as it is not moving even the camera is moving around the spring layout
I am trying to reset the camera before playing
   _CurrentAngle = 0
       dgView3D.CameraPosition = New Point3D(0, 0, 0)
       dgView3D.CameraRotation = New Point3D(0, 0, 0)
       dgView3D.ResetProjection()
but still looks that it is moved a little
any proper solution
Re: Moving camera 3D
Reply #1 - Sep 21st, 2011 at 12:04pm
What is the node's 3D position?
Hamdy Ghanem
Reply #2 - Sep 21st, 2011 at 12:05pm
I don't know as I arrange it by sprint layout
Reply #3 - Sep 22nd, 2011 at 6:39am
What do you expect to happen then if there is no relation between the node's and camera position?
You can set CameraPosition = node.LayoutTraits[View3D.Position] if you want the camera to be located at the node's position in order to look at the surrounding nodes.
If you want the camera to look at this node while pointed at the default direction (CameraRotation), place the camera at the same X,Y as the node, and at some distance along Z. You could loop over all nodes and find their largest Z value, and add some offset to it for the camera position to make sure there are no nodes behind the camera.
Hamdy Ghanem
Reply #4 - Sep 22nd, 2011 at 7:48am
Great , It  works
