Normal Topic exception, id user doubleclick on the center node (Read 4307 times)
Hamdy Ghanem
Sep 27th, 2011 at 10:56am
I have 3D diagram
have sprint layout , so it is one node in the middle and another nodes around it
when the user double click in the centered node it throw this exception
Parameter is not valid.
I tried tor rectify the issue and I realize that it is because this line
dgView3D.CameraPosition = SourceNode.LayoutTraits(View3D.Position)
this line to stop the middle one from moving (center it to camera)
If  stopped this line exception will never come
how to fix it please
Re: exception, id user doubleclick on the center n
Reply #1 - Sep 27th, 2011 at 11:04am
Does SourceNode.LayoutTraits contain a View3D.Position key at all when this happens?
Hamdy Ghanem
Reply #2 - Sep 27th, 2011 at 11:08am
yes
z=10.3225555
y=10.0109024
z=0.0184163526
Hamdy Ghanem
Reply #3 - Sep 27th, 2011 at 11:16am
I got a work around and the exception not happening now
I tried to give some deviation to the camera position to not be same as the centerNode (SourceNode) position
here is the code
     Dim pos As Point3D = SourceNode.LayoutTraits(View3D.Position)
           dgView3D.CameraPosition = New Point3D(pos.X, pos.Y, pos.Z + 0.0001)
now it works but I think you need to fix something there or at least not the exception happens
Reply #4 - Sep 27th, 2011 at 11:45am
The CameraPosition setter does not throw exceptions if I just assign that point. What is shown at the top of the callstack when you get the exception?
Hamdy Ghanem
Reply #5 - Sep 27th, 2011 at 11:47am
here is the stack trace
   at System.Drawing.Graphics.ScaleTransform(Single sx, Single sy, MatrixOrder order)
   at MindFusion.Drawing.GdiGraphics.ScaleTransform(Single sx, Single sy, MatrixOrder order)
   at MindFusion.Diagramming.WinForms.DiagramView3D.DrawDiagram3D(IGraphics graphics)
   at MindFusion.Diagramming.WinForms.DiagramView3D.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNat
iveMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.RunDialog(Form form)
   at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
   at System.Windows.Forms.Form.ShowDialog()
   at Standalone.Form1.Button2_Click(Object sender, EventArgs e) in E:\Working Folder\RAB\Organizational Dynamics\Form1.vb:line 24
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Application.Run(ApplicationContext context)
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicat
ionModel()
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String
[] commandLine)
   at Standalone.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
   at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
   at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Reply #6 - Sep 27th, 2011 at 12:16pm
What are the CameraRotation values at that point?
Hamdy Ghanem
Reply #7 - Sep 27th, 2011 at 12:17pm
zeros
(0,0,0)
Reply #8 - Oct 4th, 2011 at 6:56am
Could you check if the version below throws an exception?
https://mindfusion.eu/_beta/fcnet_3dtest.zip
If it does, can you see any "view3d:" messages logged in the debug output window?
