Normal Topic Emulating the link creation interaction (Read 2363 times)
Julien_Dechene
Sep 28th, 2011 at 3:05pm
Hello, I am trying to programmatically trigger the Diagram link creation behavior. So far I tried to set via reflection the properties (interactionStartButton, mousePosition, etc.) needed by the diagram's behavior in order to start the link creation interaction. This is a big hack I know and so far it is not working. I will look into it more thoroughly but I would like to know if it is possible, just so I don't waste my time on this. Thanks !
Julien D
Re: Emulating the link creation interaction
Reply #1 - Sep 28th, 2011 at 4:22pm
Try the DiagramView.StartInteraction method.
Julien_Dechene
Reply #2 - Sep 28th, 2011 at 5:15pm
Yup, that's what I used but I am under the impression that the OnMouseOver of the diagram view overrides the interaction right away. I think I am trying to customize a bit too much. Thanks for the infos though, they are as always much appreciated.
Julien_Dechene
Reply #3 - Sep 28th, 2011 at 5:24pm
Oh !!! I was using StartInteraction(Point mousePosition, MouseButtons mouseButton) instead of StartInteraction(InteractionState interactionState, PointF point). With the public StartInteraction (second one) it works almost like I want it to. Thanks a lot Stoyo, you're awesome !!! Grin
