Normal Topic how to layout the shapeNode? (Read 1507 times)
Green
Oct 24th, 2011 at 3:22am
there is a shapeNode including a image and some text ,I want to the text under the image ? That is the image is the top , the text  below the image ,what can i do?
Thank you !
Re: how to layout the shapeNode?
Reply #1 - Oct 24th, 2011 at 7:40am
If you will be using short labels and images of the same height, you could set ImageAlign to Top, TextFormat.LineAlignment to Far, and set a node size that will fit the image and text.
Otherwise you can define ImageRectangle and text region for your shapes such that the ImageRectangle is at the top and the text region is at the bottom. E.g. adding this xml to the shape library file will allocate the top 3/4 for an image, and the bottom 1/4 for text:
<image x="0" y="0" width="100" height="75" ... />
<textarea>
  <line dash-style="Custom" width="-1">
<point x="5" y="75" />
<point x="95" y="75" />
  </line>
<point x="95" y="100" />
  </line>
<point x="5" y="100" />
  </line>
  </line>
</textarea>
Green
Reply #2 - Oct 25th, 2011 at 8:29am
Thabk you!
