Normal Topic Rotate title in row header (Read 4858 times)
Amosius
Oct 31st, 2011 at 4:00pm
i have one row header with several sub headers. I would like to display its title rotated, so that i have to rotate my head for 90 degrees to read my titles Smiley
I use the property header.RotateTitle = true but my title will then be placed horizontal and not vertical, at a different position (somewhere in column header).
Amosius
Re: Rotate title in row header
Reply #1 - Nov 1st, 2011 at 1:19pm
Our bad; RotateTitle should work with this version:
https://www.mindfusion.eu/_beta/wpfdiag271.zip
Amosius
Reply #2 - Nov 10th, 2011 at 5:33pm
Hello Stoyan,
yep, works fine.
I also use inplace edit to change titles. I guess it's quite easy to manipulate the size of the textbox when user wants to edit a title?!
Amosius
Reply #3 - Nov 11th, 2011 at 8:01am
It should be possible by setting the TextBox' Width and Height from the EnterInplaceEditMode handler.
Amosius
Reply #4 - Jan 11th, 2012 at 4:44pm
Hello Stoyan,
do you know when you will release 2.71?
Amosius
Reply #5 - Jan 12th, 2012 at 7:56am
Hi Amosius,
We should release it next week.
Amosius
Reply #6 - Jan 30th, 2012 at 8:51am
Hello Stoyan,
can I expect a release this week?
Reply #7 - Jan 31st, 2012 at 2:50pm
Yes.
Amosius
Reply #8 - Feb 2nd, 2012 at 4:54pm
Thank you very much.
