Normal Topic How delete single or selected nodes? (Read 4160 times)
PDM.
Senior Member
Nov 7th, 2011 at 9:07am
Hello Sotyo
Simple question
diagram.ClearAll();  clear all on the diagram
How delte or rmeove only selected?
What is the equivalent in code to what do delete key?
Best regards
PDM.
Senior Member
Re: How delete single or selected nodes?
Reply #1 - Nov 7th, 2011 at 9:50am
  private void form_NodeSelecting(object sender, NodeValidationEventArgs e)
nodetodelete = e.Node as DiagramNode;
form.Nodes.Remove(nodetodelete);
Thsi work but delete only one node, if multiple nodes selected only one is deleted, basically the last is selected.
How delte multiple selected nodes?
Reply #2 - Nov 7th, 2011 at 10:03am
You could collect the nodes in a List<DiagramNode> instance, and then call form.Nodes.Remove from a loop over the list.
PDM.
Senior Member
Reply #3 - Nov 7th, 2011 at 10:29am
Lol sorry, but like always i request, can put a complete example please.
Reply #4 - Nov 7th, 2011 at 11:43am
You can actually access the selected nodes through the Selection object, so it should look something like:
private void OnDelete(sender, args ...)
	var selectedNodes = form.Selection.Nodes.Clone();
	foreach (DiagramNode nodetodelete in selectedNodes)
