Normal Topic Stop dragging of Link once they created (Read 1995 times)
SL_developer
coding rocks
Nov 16th, 2011 at 6:59am
How can I prevent the dragging of Link once they created with any Node?
If I have two Nodes A & B , created the link from A to B, I need to Cancel the dragging of this link to any other Node.
I found one Event, this event raise while modifying the created link
  void ddtarget_LinkModified(object sender, LinkEventArgs e)
so please tell me what code I need to write in this event for preventing the link modification.
Re: Stop dragging of Link once they created
Reply #1 - Nov 16th, 2011 at 7:06am
You could set the link's AllowMoveStart and AllowMoveEnd properties to false from the LinkCreated handler. Alternatively, call e.CancelDrag() from LinkModifying handler.
SL_developer
coding rocks
Reply #2 - Nov 16th, 2011 at 7:18am
Hi
Thanks for quick reply,
AllowMoveStart and AllowMoveEnd properties are working & also e.CancelDrag() too.
Thank you so much.
