Normal Topic Positioning shapenode in LaneGrid (Read 1927 times)
binuvc
Nov 18th, 2011 at 6:54am
I was trying to add a shapenode to a LaneGrid (with multiple rows and columns) from code behind.
I tried creating a lanegrid and placed shapenodes in cells from UI and exported the diagram to xml to figureout which properties need to be set to achieve the same. But couldnot find any properties referencing  the LaneGrid row or column in the xml node "<Node>"
I am not using the SwimLaneLayout. Just using the LaneGrid.
Please advice.
Re: Positioning shapenode in LaneGrid
Reply #1 - Nov 18th, 2011 at 10:51am
There isn't any built-in association between nodes and the background grid. If you need that, you could store row and column values in your custom properties, or in object assigned to the nodes' Tag property.
If you need to align a node to a specific grid cell, you could call diagram.LaneGrid.GetCellBounds(col, row), and assign the result to node.Bounds.
