Hot Topic (More than 10 Replies) Re: layout for silverlight diagramming (Read 8238 times)
Nov 28th, 2011 at 5:58pm
Check TreeLayout and LayeredLayout,  they are shown in the first two tutorials.
Reply #1 - Nov 29th, 2011 at 10:00am
http://www.mindfusion.eu/onlinehelp/diagramlite/index.htm?Tutorial_1__Loading_Gr...
You can also find the tutorial projects under the control's installation folder.
vchimakurthi
Reply #2 - Nov 30th, 2011 at 5:54pm
hi
i set layout of diagram using
var layout = new MindFusion.Diagramming.Silverlight.Layout.TreeLayout
layout.Arrange(siteMap);
its looking fine like organisation chart but the lines are straight lines between nodes i want them like in organisation chart (bended hierarchy one)
what property i cant set
and
how to set image in a node..?
thanks
thanks
Reply #3 - Nov 30th, 2011 at 6:06pm
Set TreeLayout.LinkStyle to Cascading3. If you are using ShapeNodes, you can set their Image property. See tutorial 3 for an example showing how to show an image from Xaml template.
vchimakurthi
Reply #4 - Dec 1st, 2011 at 10:41am
hi,
i set
           node.ImageAlign = ImageAlign.MiddleLeft;
           node.ImageStretch = Stretch.Uniform;
           //node.ResizeToFitText();
           node.TextAlignment = TextAlignment.Right;
           node.Transparent = true;
           node.TextWrapping = TextWrapping.Wrap;
           siteMap.AutoScroll = true;
but image and text are overlapping i want wrapped text by the side of image
and
how can i resizeto fit diargram so that whole treeview can be  viewed (organisation chart)
i set
               siteMap.ResizeToFitItems(0.2);
              layout.Type = TreeLayoutType.Centered;
when i bind to template as shown in tutorial 3
its not showing any image or text only links are visible..? i am not setting bounds..
many thanks
Reply #5 - Dec 1st, 2011 at 11:12am
If you need the image and text displayed side by side in a ShapeNode, you will have to define a custom Shape that provides a TextRectangle and ImageRectangle coordinates.
You should call ResizeToFitItems after applying the layout, not before that.
Regarding the tutorial, check if you haven't omitted the DefaultStyleKey = typeof(OrgChartNode) assignment. Perhaps it will be easier to add the OrgChartNode files to your project and refactor them for your needs.
vchimakurthi
Reply #6 - Dec 1st, 2011 at 12:22pm
hi,
no i am not missing
<Image Source="{TemplateBinding Image}"
Stretch="Uniform">
</Image>
<TextBlock Text="{TemplateBinding Text}" FontSize="9" />
nodes are added
var  node = new OrgChartNode
Text = name,
Image = new BitmapImage(new Uri("person.jpg", UriKind.Relative))
Bounds = new Rect(0, 0, 20, 10)
node.Id = id;
siteMap.Nodes.Add(node);
still not showing text /images
how come the tutorial showing images text side by side with out custom shape classe
thanks
« Last Edit: Dec 1st, 2011 at 2:20pm by vchimakurthi »
Reply #7 - Dec 1st, 2011 at 1:04pm
What does your full template look like?
The tutorial completely replaces the ShapeNode template to specify image and text position, so it does not need a custom Shape. You need custom shapes only to do that with standard ShapeNodes.
vchimakurthi
Reply #8 - Dec 1st, 2011 at 5:08pm
hi
is generic.xaml need to be in themes folder ?
then it shows nodes otherwise not
thanks
Reply #9 - Dec 1st, 2011 at 6:08pm
Yes, generic.xaml must reside in the themes folder, otherwise Silverlight cannot find the template.
vchimakurthi
Reply #10 - Dec 5th, 2011 at 1:58pm
hi ,
context menu is not displaying at mouse position.
i write the code like
private void OnNode_Clicked(object sender, NodeEventArgs e)
if (e.MouseButton == MouseButton.Right)
Point p = e.MousePosition;
ctxpopup.Visibility = Visibility.Visible;
ctxpopup.IsOpen = true;
ctxpopup.SetValue(Canvas.LeftProperty, (double)p.X);
ctxpopup.SetValue(Canvas.TopProperty, (double)p.Y);
but displays at random location
thanks
Reply #11 - Dec 5th, 2011 at 2:48pm
The e.MousePosition property returns the position in diagram's logical coordinates. In the general case, they are not the same as the coordinates relative to the application's root element - e.g. when the diagram is scrolled, zoomed, or has some margin relative to the root visual. You can get the position relative to a parent element like this:
var transform = diagram.DocumentPlane.TransformToVisual(parentCanvas);
var position = transform.Transform(e.MousePosition);
// assuming ctxpopup position is relative to parentCanvas
ctxpopup.SetValue(... position.X ...);
vchimakurthi
Reply #12 - Dec 6th, 2011 at 9:19am
hi ,
thats working fine thanks.
i am showing context menu (popup) on node click.
it works fine only once its not showing popup again
i need to refresh the screen every time...?
           ctxpopup.Child = propGrid;
           ctxpopup.VerticalOffset = 75.0;
           ctxpopup.HorizontalOffset = 25.0;
on  click event
thanks
Reply #13 - Dec 6th, 2011 at 9:39am
Doesn't the NodeClicked event get fired anymore, or setting ctxpopup.IsOpen = true doesn't show the menu?
