Normal Topic How to distribute FlowChart.Net (Read 1857 times)
CanadaProgrammer
Nov 29th, 2011 at 9:13pm
I put MindFusion.Common.dll,MindFusion.Diagramming.dll,MindFusion.Diagramming.WinForms
.dll to installation package. Then these dll files will be installed to dll directory in user computer. My program can run, looks good.
But when I try to create a diagram, my program throw a exception. Looks a file named MindFusion.Graphics.dll is missed. Then I copied this file to the same directory where these three dll files are in and also copy the file to the current directory where my program are in. But it did not work.
So how to distribute FlowChart.Net?
Re: How to distribute FlowChart.Net
Reply #1 - Nov 30th, 2011 at 6:50am
It should show a different message after you copy the mindfusion.graphs.dll, what is it? If your setup software cannot detect dependencies, try adding manually all dll files you can see in the bin/debug or bin/release subfolders under the project's source code project. If the project runs successfully from Visual Studio, then all necessary assemblies should be there.
