Normal Topic Problem with scrollbars (Read 3347 times)
JR
Nov 30th, 2011 at 4:26pm
Hello again !!
Again because I am working on 2 similar projects using JDiagram and Flowchart activeX and I have today a topic with JDiagram.
I am working with powerbuilder.
I have a problem with the scrollbars.
I have the flowchart control in a window.
I create a graph (for the moment, only boxes).
My graph is very large (several times the width of the screen).
The horizontal scrollbar is displayed but is disabled.
I can't go to the right part of the document.
If I resize my window to the screen width, the scrollbar becomes enabled but I can't go the right of my graph.
It is as if the visible part of the document is limited to screen size.
I saved my graph with the savetofile method.
Your VB flowcharter sample can load this file and I still have the same problem : the most part of the graph is not accessible.
I can give you the file if you want.
What can be the origin of the problem ?
Regards
Re: Problem with scrollbars
Reply #1 - Nov 30th, 2011 at 4:48pm
Call the FitDocToObjects or SetDocSize method to make the scrollable area large enough. That's what corresponds to Diagram's setBounds and resizeToFitItems methods in the Java control.
JR
Reply #2 - Dec 1st, 2011 at 8:29am
Great !!
