Normal Topic Restriction on create a new node (Read 3721 times)
qomo-peter
Nov 30th, 2011 at 4:31pm
When creating a new DiagramNode by moving the mouse on the diagram, either the width or the high of bounds is too small, the node will be canceled.
Is that right? and how to disable it. I want to create a node without restriction.
Re: Restriction on create a new node
Reply #1 - Nov 30th, 2011 at 4:51pm
Try setting a very small MinimumNodeSize value.
qomo-peter
Reply #2 - Dec 1st, 2011 at 12:56am
Sad I have tried, but failed.
Reply #3 - Dec 1st, 2011 at 8:36am
In what way did you fail? Smiley Note that a zero size is the default, and the control interprets it as a MeasureUnit -indepent value of couple of millimeters. You will have to set it to something like 0.1 x 0.1 to have any effect.
If this is about the FreeLine class we discussed earlier, you could just override its AllowCreate method to disregard MinimumSize:
protected override bool AllowCreate(Point current, InteractionState ist)
	return true;
qomo-peter
Reply #4 - Dec 1st, 2011 at 2:04pm
Grin You got it, all about the freeline. I can't finished it without your help.
it works with setting:
diagram.AlignToGrid = false;
but override the AllowCreate works better.
Another question, I can't draw a new line from an exist line or node, the cursor becomes  "select frame".How can I draw a line from any point of diagram?
Reply #5 - Dec 1st, 2011 at 3:12pm
You should be able to draw a FreeLine from another FreeLine if the latter does not show selection frame. Make sure SelectAfterCreate is disabled and ModificationStart is not set to AutoHandles. To prevent interactive selection completely, set e.Cancel = true from the NodeSelecting handler.
To disable drawing standard DiagramLinks from a node, you will have to create a custom behavior class and assign its instance to the CustomBehavior property:
class MyBehavior : DrawNodesBehavior
	public MyBehavior(Diagram diagram) : base(diagram) {}
	protected override DiagramNode CreateNode()
		return new FreeLine();
diagram.CustomBehavior = new MyBehavior(diagram);
qomo-peter
Reply #6 - Dec 1st, 2011 at 3:27pm
Cheesy
Great, the FreeLine works perfect now.
Thanks a lot.
