Normal Topic Information-Server (Read 2688 times)
heni86_2003
Information-Server
Dec 6th, 2011 at 12:30pm
I'm using the MindFusion Diagramming for SilverLgiht, and I would like to know how we can retrieve the information from the server side.
Thank you
Re: Information-Server
Reply #1 - Dec 6th, 2011 at 12:35pm
What kind of information? Do you mean you need to submit the diagram drawn by users on client side and parse object relations, labels, etc on the server?
heni86_2003
Reply #2 - Dec 6th, 2011 at 12:51pm
I filled out the diagram from an xml file. And I would like get the changed data and stored in sharepoint.
Reply #3 - Dec 6th, 2011 at 1:40pm
If you need to store it in your custom format, you could use the Linq for Xml API to generate an XDocument and send the XDocument.ToString() result to the server. E.g. this saves in format similar to the one shown in Tutorial 1:
var doc = new XDocument(
	new XElement("Graph",
		new XElement("Nodes",
			from ShapeNode n in diagram.Nodes select new XElement(
				"Node", new XAttribute("id", n.ZIndex), new XAttribute("name", n.Text))),
		new XElement("Links",
			from l in diagram.Links select new XElement(
				"Link",
				new XAttribute("origin", l.Origin.ZIndex),
				new XAttribute("target", l.Destination.ZIndex)))
Or you could use the control's intrinsic XML format to store and load data. In such case use the SaveToString and LoadFromString methods of Diagram.
