Normal Topic How to find indexes of nodes connected by a link (Read 1764 times)
lyrock
Dec 8th, 2011 at 6:50am
the codes are like following. Thanks
Dim link As DiagramLink
Dim numLink As Integer = view.Diagram.Links.Count
For j As Integer = 0 To numLink - 1
link = view.Diagram.Links(j)
int StartIndex = StartNode's index of the link (?)
int EndIndex = EndNode's index of the link (?)
Next
Re: How to find indexes of nodes connected by a li
Reply #1 - Dec 8th, 2011 at 8:30am
You can get references to the nodes that a link connects using the Origin and Destination properties of the DiagramLink class. I'm not sure what kind of indices you need to find. If it's the index of a node within the diagram.Nodes collection, try this:
startIndex = diagram.Nodes.IndexOf(link.Origin)
endIndex = diagram.Nodes.IndexOf(link.Destination)
lyrock
Reply #2 - Dec 8th, 2011 at 2:31pm
Thank you.
This is exactly what I want.
