Normal Topic AdjustmentHandle visibility error (Read 3809 times)
binuvc
Dec 9th, 2011 at 12:55pm
We have a scenario where we have to reload the shape nodes from our collection on some event.
so we are calling
diagram.ClearAll();
diagram.UpdateLayout();
before reloading the nodes.
But for some node if the adjustmentHandels were visible, they are not removed from the screen and we are able to see invalid squares (which were previously adjustment handles) after reloading.
it throws error on clicking these squares.
Message: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.NullReferenceException: Object reference not set to an instance of an object.
at MindFusion.Diagramming.Silverlight.InteractionState.Start()
at MindFusion.Diagramming.Silverlight.BehaviorBase.OnMouseMove(MouseEventArgs e)
at MindFusion.Diagramming.Silverlight.Diagram.x2c5d1da1234c3a6a(Object xe0292b9ed559da7d, MouseEventArgs xfbf34718e704c6bc)
at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
Please advice.
Thanks in advance
binuvc
Re: AdjustmentHandle visibility error
Reply #1 - Dec 9th, 2011 at 5:28pm
Are you trying the clear the whole diagram from some validation event handler? I don't think that's a good idea, but check if it works if you also call CancelDrag() and Selection.Clear() before ClearAll().
binuvc
Reply #2 - Dec 12th, 2011 at 12:42pm
We tried the same and it is still not working.
The problem is that our design has a controller class which solely has the right to modify the object model representing the diagram. so when ever a modification is required we inform the same to the controller and which inturn modifies the object model and we just reloads the diagram based on the modified object model.
The following is what we are doing on clear all:
UnHookEvents(); // unhooks all the events attached on the diagram control
diagramLite.CancelDrag();
diagramLite.Selection.Clear();
diagramLite.ClearAll();
diagramLite.UpdateLayout();
HookEvents();
binuvc
Reply #3 - Dec 12th, 2011 at 4:01pm
Ok, but are you doing that from some validation event such as NodeModifying or NodeCreating? These are called after each mouse movement, there's a lot of contextual information kept during interaction made invalid by ClearAll, and so they are not a good place to reload the diagram. You could probably use the after-the-fact events for this update, e.g. NodeCreated or NodeModified.
binuvc
Reply #4 - Feb 3rd, 2012 at 11:55am
We moved the code to link_Created event and still the issue is persisting.
  private void diagram_LinkCreated(object sender, LinkEventArgs e)
            if (e.Link.Origin != e.Link.Destination)
                 this.Dispatcher.BeginInvoke(LoadView);
Please advice.
BinuVC
Reply #5 - Feb 6th, 2012 at 8:19am
Sorry but I could not reproduce this. Please attach a sample project that shows the problem.
