Normal Topic AnchorPoints -  ShowAnchors & SnapToAncho (Read 2898 times)
moelski
Dec 16th, 2011 at 10:19pm
Hi !
After drawing my own nodes based on a DiagramNode (thx to Stoyo!!) I need some Anchorpoints.
I loaded your IconNode Sample and modify the code for the node creation:
private void diagram_Clicked(object sender, DiagramEventArgs e)
IconNode iconNode = new IconNode(diagram);
		var apat2 = new AnchorPattern(new AnchorPoint[]
new AnchorPoint(10, 0, true, false, MarkStyle.Circle, Color.RoyalBlue),
new AnchorPoint(50, 0, true, false, MarkStyle.Circle, Color.Blue),
new AnchorPoint(90, 0, true, false, MarkStyle.Circle, Color.Firebrick),
new AnchorPoint(10, 100, false, true, MarkStyle.Rectangle),
new AnchorPoint(50, 100, false, true, MarkStyle.Rectangle),
new AnchorPoint(90, 100, false, true, MarkStyle.Rectangle),
new AnchorPoint(0, 50, true, true, MarkStyle.Custom)
    iconNode.AnchorPattern = apat2;
diagram.Nodes.Add(iconNode);
iconNode.Move(e.MousePosition.X, e.MousePosition.Y);
I need to show the Anchorpoints always so I try setting "ShowAnchors" to "Always".
But the result is that the points are gone. If set it back to selection I see the points when I hover over the node with the mouse.
The next problem is the snapping. I need always the same Anchorpoints. So I set SnaptToAnchor to "OnCreate". But if you run the above code, create 2 nodes, link them you could a nive effect.
Move one node around the other and you will see that the link is snapping  Angry
Maybe I did something completely wrong but I can´t find any hints in the help which pointing to some known issues.
And one last question about AnchorPoints. Is it a problem to replace the Points if the drawing of the node changes? I have a node where I can enable / disable an additional text. This causes some changes in the Draw methode. So can I change the positions of the Anchors within the Draw methode of my node?
Greetz
  Dominik
Re: AnchorPoints -  ShowAnchors & SnapToAncho
Reply #1 - Dec 19th, 2011 at 7:53am
1) Add these lines to IconNode.Draw:
if (ShouldRenderAnchors(options))
	DrawAnchors(graphics);
2) Move one node around the other and you will see that the link is snapping ...
Do you mean the link anchor points change when moving the nodes? That will happen if the link's Dynamic property is enabled, or if AutoRoute is enabled and RoutingOptions.Anchoring is set to Reassign.
3) You can replace anchor points, but at this time links can't detect the change automatically to update their positions. You will have to loop over the node's links and reset the anchor points like this after changing AnchorPattern:
int orgPoint = link.OriginAnchor;
link.OriginAnchor = -1;
link.OriginAnchor = orgPoint;
int destPoint = link.DestinationAnchor;
link.DestinationAnchor = -1;
link.DestinationAnchor = destPoint;
moelski
Reply #2 - Dec 19th, 2011 at 12:15pm
Hi !
Thx for the information.
I found a solution to draw custom AnchorPoints:
	  private void diagram1_DrawAnchorPoint(object sender, DrawAnchorPointEventArgs e)
		var idx = e.AnchorIndex;
		// ein Pixel sind wieviel Prozent ??
		var PixelProProz = e.Node.Bounds.Height / 100;
		// ein Prozent sind wievile Pixel ??
		var ProzProPixel = 100 / e.Node.Bounds.Height;
		var ins = e.Node.AnchorPattern.Points.Cast<AnchorPoint>().Count(point => point.AllowIncoming);
		// Top offset berechnen
		float topoff = 6;
		var y = topoff + (idx * 9);
		var posDraw = new PointF
		    X = -2 + e.Node.Bounds.X,
		    Y = y + e.Node.Bounds.Y
		var posPoint = new PointF
		    X = -2 * ProzProPixel,
		    Y = (y + 3) * ProzProPixel
		var drawPen = new Pen(Color.Black)
		    Width = 1
		e.Graphics.FillEllipse(Brushes.Red, posDraw.X, posDraw.Y, 6, 6);
		e.Graphics.DrawEllipse(drawPen, posDraw.X, posDraw.Y, 6, 6);
		// AnchorPoint umsetzen
		e.AnchorPattern.Points[idx].X = posPoint.X;
		e.AnchorPattern.Points[idx].Y = posPoint.Y;
		SiAuto.Main.LogVerbose("Point {0} {1}", idx, posPoint);
There is only one question left.
Is there a way to realize a snapping and hoovering effect?
Hoover : If the user places the mouse over an Anchorpoint the point gets another color or an additional border. So he will instantly see that he could start / end a link there.
Snapping : If the user draws a link the endpoint automatically catches / snaps the closest AnchorPoint.
« Last Edit: Dec 20th, 2011 at 6:45am by moelski »
Reply #3 - Dec 20th, 2011 at 7:41am
Hover: Handle MouseMove like this:
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	var diagramPos = diagramView.ClientToDoc(e.Location);
	var node = diagram.GetNodeAt(diagramPos, 3) as IconNode;
	if (node != null)
		node.highlightedAnchor = -1;
		for (int idx = 0; idx < node.AnchorPattern.Points.Count; idx++)
			// point position from your code
			float topoff = 6;
				X = -2 + node.Bounds.X,
				Y = y + node.Bounds.Y
			if (Utilities.Distance(posDraw, diagramPos) < 4)
				node.highlightedAnchor = idx;
				diagram.Invalidate(node.Bounds);
				break;
where highlightedAnchor is a member of your custom node type:
internal int highlightedAnchor = -1;
and you check it in the DrawAnchorPoint handler:
e.Graphics.FillEllipse((e.Node as IconNode).highlightedAnchor == idx ?
	Brushes.Yellow : Brushes.Red, posDraw.X, posDraw.Y, 6, 6);
Snapping: links snap to anchor points by default. If you are using auto-routing, make sure RoutingOptions.Anchoring is not set to Ignore.
moelski
Reply #4 - Dec 20th, 2011 at 10:10am
Hi Stoyan,
again a great info.
Is there an option to allow only drawing links from Outgoing Anchors?
Reply #5 - Dec 20th, 2011 at 10:31am
If you mean there should not be a link drawn when the node does not have appropriate anchor points, set AllowUnanchoredLinks to false. If you want to allow drawing a link only when the mouse cursor is directly over a point, you can implement it using a custom Behavior class as shown here -
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=128273...
