Normal Topic Readonly diagram (Read 3039 times)
winT
Readonly diagram
Dec 25th, 2011 at 10:59am
How can I set a diagram to readonly ?
Re: Readonly diagram
Reply #1 - Dec 26th, 2011 at 8:51am
Set DiagramView.Behavior = DoNothing.
winT
Reply #2 - Dec 26th, 2011 at 9:32am
I use diagram , not diagramView ...
Reply #3 - Dec 26th, 2011 at 9:53am
You can't show a Diagram without a DiagramView if you are using the Windows Forms control. If you are using WPF or Silverlight, set Behavior on the Diagram object.
winT
Reply #4 - Dec 26th, 2011 at 10:41am
Thank you , I use winForm and It works!
