Normal Topic Compatibility with jQuery? (Read 3400 times)
Rick
Dec 27th, 2011 at 11:47pm
I'm just starting to experiment with JsDiagram and noticed that it requires the MicrosoftAjax.js library. I'm wondering if there will be a version that uses jQuery instead?
The reason I ask is I'm looking to use this with a Ruby on Rails app which, in Rails 3, use jQuery as the default javascript framework.
Thanks in advance!
Rick
Re: Compatibility with jQuery?
Reply #1 - Dec 28th, 2011 at 7:09am
JsDiagram builds upon the ms-ajax type system, which does not have equivalent in jQuery AFAIK. Also it does not use any DOM queries, selectors etc. so there's not much we can use jQuery for. Anyway you can load both MicrosoftAjax.js and jquery.js into your page, there aren't any collisions between them (Microsoft distributes both libraries with ASP.NET for use in ASP.NET Ajax applications).
