Normal Topic how to limit the default shapes in the ShapeListBox. (Read 1563 times)
umesh
Dec 30th, 2011 at 10:47am
I want to show only four shapes of particular type in the ShapeListBox and allow user to drag on the canvas. How to achieve this.
Umesh V
Re: how to limit the default shapes in the ShapeListBox.
Reply #1 - Dec 30th, 2011 at 11:28am
You could set the ShapeListBox' ShapeLibraryLocation property to a shape library file that defines your shapes. You could as well remove unnecessary shapes from an AppletStartedScript handler:
function slbLoaded()
      var applet = <%= shapeListBox.AppletElement %>;
      applet.getShapeListBox().clearShapes();
      addShapesToList(applet, [ "Rectangle","Ellipse"]);
function addShapesToList(shapelistApplet, shapeIdArray)
      var scriptHelper = shapelistApplet.getScriptHelper();
      var slb = shapelistApplet.getShapeListBox();
      for (i = 0; i < shapeIdArray.length; ++i)
            var shape = scriptHelper.shapeFromId(shapeIdArray[i]);
            slb.addShape(shape);
umesh
Reply #2 - Dec 30th, 2011 at 1:55pm
Thanks Stoyan.
It works.
