Normal Topic Diagram.LoadFromXml - Link Headshape disappear (Read 6084 times)
kev
Never touch a running
system.
Jan 3rd, 2012 at 1:15pm
Hi there,
I've got a problem with XML
I'm using Diagram.SaveToXml(XmlDocument) for storing the diagram. In the generated XML the headshape-id is set : <HeadShape Id="Arrow" />
But when I load the XML using Diagram.LoadFromXml(XmlDocument) the arrow does not show up in the diagram. When I save it again, there is no headshape-id set in the XML. I think there is a bug in the load method.
Infos: I'm using VS2005, .Net 2.0, FlowChart.Net 5.7 Trial
Re: Diagram.LoadFromXml - Link Headshape disappear
Reply #1 - Jan 3rd, 2012 at 1:25pm
Are you using a class derived from DiagramLink? In such case, check this topic:
http://mindfusion.eu/Forum/YaBB.pl?num=1320386783
kev
system.
Reply #2 - Jan 3rd, 2012 at 1:37pm
Hi Stoyan,
it works, I've register the derived classes with classVersion=101 and the arrow is there.
Thanks a lot.
