Normal Topic Diagram.HitTestAdjustmentHandles Event (Read 4858 times)
Kuzya
Jan 11th, 2012 at 11:26am
with the function HitTestAdjustmentHandles I lack one  function if an element is selected. If with left mouse key a click is made in internal area of the element, it must be indicated.
It must tramp exactly like with ShapeHandlesStyle = SquareHandles (8 quadrangles on the edge of the element and a quadrangle in the middle).
Could you inform me like me of this better can make?!
Many thanks in advance.
Re: Diagram.HitTestAdjustmentHandles Event
Reply #1 - Jan 11th, 2012 at 11:51am
I'm not sure if I understand you correctly. If you need your custom hit-testing code to be based on some of the standard handle styles, you could do something like this in the HitTestAdjustmentHandles handler:
e.Node.HandlesStyle = HandlesStyle.SquareHandles;
int handle = 8;
e.Node.HitTest(e.MousePosition, ref handle);
e.Node.HandlesStyle = HandlesStyle.Custom;
// additional custom testing
e.HitResult = handle;
Kuzya
Reply #2 - Jan 11th, 2012 at 12:56pm
Sorry for my English Smiley
If a click is made with the left mouse key in the internal area of the element, it must appear as it does when for ShapeHandlesStyle = SquareHandles   the left mouse key in the element is clicked.
Reply #3 - Jan 11th, 2012 at 1:52pm
If dragging from any point within the node's interior should start moving the node, while resize is still enabled at the corners, you could handle it like this:
private void diagram_HitTestAdjustmentHandles(object sender, HitTestEventArgs e)
    int handle = 8;
    DiagramNode node = (DiagramNode)e.Item;
    node.HandlesStyle = HandlesStyle.SquareHandles;
    node.HitTestHandle(e.MousePosition, ref handle);
    node.HandlesStyle = HandlesStyle.Custom;
    if (handle > 0 && handle <= 8)
        // a resize or move handle was hit
        return;
    if (node.ContainsPoint(e.MousePosition))
        e.HitResult = 8;
private void diagram_DrawAdjustmentHandles(object sender, MindFusion.Diagramming.DrawItemEventArgs e)
    InternalUtils.DrawSelHandles(
        e.Graphics,
        diagram.SelectedItemHandlesStyle,
        diagram.DisabledHandlesStyle,
        node.Bounds, 0,
        node.EnabledHandles,
        false,
        HandlesStyle.SquareHandles2,
        diagram.AdjustmentHandlesSize);
You could also set ModificationStart = AutoHandles to allow moving a node without having to select it first.
Kuzya
Reply #4 - Jan 11th, 2012 at 3:47pm
If we have ShapeHandlesStyle = SquareHandles and with left mouse key a click in internal area of the element is made, then element looks thus:
Attachment1
I have HitTestAdjustmentHandles, so ShapeHandlesStyle = Custom; if with left mouse key a click is made in internal area of the element, element looks thus:
Attachment2
And now my Asking: how do I make this that with me with the click with left mouse key in internal area of the element is just like with ShapeHandlesStyle = SquareHandles?
Dok2.docx (Attachment deleted)
Dok3.docx (Attachment deleted)
Reply #5 - Jan 11th, 2012 at 5:19pm
If you set HandlesStyle to Custom, you must also handle the DrawAdjustmentHandles event. The code from my previous post contained a sample handler. You can replace SquareHandles2 with SquareHandles there to get exactly the same look as the standard SquareHandles style.
