Normal Topic 2 parents node in the 3D diagram (Read 3851 times)
Hamdy Ghanem
Jan 17th, 2012 at 10:02am
I have 3D diagram and I have 2 source (parent ) node and each node is linked to some child nodes
When I try to arrange by springLayout  the parent nodes override places of each others. all in the same place.
How to put space between parents
Re: 2 parents node in the 3D diagram
Reply #1 - Jan 17th, 2012 at 12:05pm
It seems the MultipleGraphsPlacement option offsets only 2D coordinates. Try running the 3D SpringLayout with SplitGraph set to false, then it should treat all nodes as part of the same graph and the two parts should repulse each other. Alternatively, offset the nodes from the second graph yourself, e.g. add some value to their X coordinate so that minimum X of second graph is larger than max. X of the first graph.
Hamdy Ghanem
Reply #2 - Jan 17th, 2012 at 1:31pm
How to do this?offset the nodes from the second graph yourself, e.g. add some value to their X coordinate so that minimum X of second graph is larger than max. X of the first graph.???
Hamdy Ghanem
Reply #3 - Jan 17th, 2012 at 1:50pm
It looks like this now
how can I decrease the distance between the 3 groups
Reply #4 - Jan 17th, 2012 at 2:51pm
Try running the 3D layout with a smaller RepulsionFactor value. Or add some temporary links between the parent nodes and run the layout (possibly with EnableClusters set to true), then remove the links.
