Normal Topic Multiple resources in timetable view (Read 2599 times)
john6630
Jan 20th, 2012 at 4:07pm
Hi Meppy,
I have a plant schedule for which I want to display a timetable view. On each day I want to put multiple machines. I want each machine to have its own column not have all machines on one column with collisions enabled. Can this be done? If so, how?
John
Re: Multiple resources in timetable view
Reply #1 - Jan 23rd, 2012 at 6:30am
You can define the machines as resources, then enable grouping in the control:
Resource machine1 = new Resource();
machine1.Name = "machine 1";
calendar1.Schedule.Resources.Add(machine1);
Resource machine2 = new Resource();
machine2.Name = "machine 2";
calendar1.Schedule.Resources.Add(machine2);
calendar1.Resources.Add(machine1);
calendar1.Resources.Add(machine2);
calendar1.GroupType = GroupType.GroupByResources;
Now, the appointments associated with each machine will be displayed in their own column.
john6630
Reply #2 - Jan 24th, 2012 at 3:01am
Hi Meppy,
Thank you for your speedy reply. I will try your suggestion and post more if I have a problem.
John
