Normal Topic zoom out blues (Read 2312 times)
ulthien
zoom out blues
Jan 23rd, 2012 at 2:55pm
hello,
when i zoom out a diagram and drag in from another diagram, the coordinates in zoomed out target still are scaled as if the view were not zoomed out. (When zoom is 100% all is perfect, including givefeedback on cursor too)
So when i drop a node, instead of being dropped in lowest corner right, it drops somewhere proportionally to left and up as if the viewport were not zoomed at all.
I tried various transform and TransformToVisual converting, but no luck.
Is there some special update needed after zoom?
Re: zoom out blues
Reply #1 - Jan 23rd, 2012 at 3:15pm
It should be enough to call DragEventArgs.GetPosition(diagram.DocumentPlane) to get the diagram cooridnates of the drop point.
ulthien
Re: zoom out blues
Reply #2 - Jan 23rd, 2012 at 3:25pm
thank you!
i had a DragEventArgs.GetPosition(diagram) and that was wrong.
cheers  Smiley
