Normal Topic Text on link base and head (Read 2989 times)
binuvc
Jan 24th, 2012 at 8:08am
   Is there any way we can place text near the link base and link head?
   The Text property of the link is already being used for displaying some other information.
   Please advice
BinuVC
Re: Text on link base and head
Reply #1 - Jan 25th, 2012 at 9:33am
You will have to derive from DiagramLink to add new text properties:
using System;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Media;
using System.Windows.Shapes;
using MindFusion.Diagramming.Silverlight;
namespace Test
	public class MyLink : DiagramLink
		public MyLink(Diagram diagram) : base(diagram)
		public MyLink(Diagram d, DiagramNode origin, Point point) :
			base(d, origin, point)
		protected override void UpdateVisuals()
			base.UpdateVisuals();
			var canvas = Content as Canvas;
			if (canvas != null)
				if (!canvas.Children.Contains(baseTextBlock))
					canvas.Children.Add(baseTextBlock);
					baseTextBlock.SetBinding(TextBlock.TextProperty,
						new Binding("BaseText") { Source = this });
				const int margin = 5;
				var linkBounds = GetBounds();
				var points = ControlPoints;
				var measure = new TextBlock
					Text = BaseText, FontFamily = FontFamily, FontSize = FontSize
				measure.UpdateLayout();
				if (points[0].Y > points[1].Y)
					Canvas.SetTop(baseTextBlock,
						points[0].Y - linkBounds.Y - margin - measure.ActualHeight);
				else
						points[0].Y - linkBounds.Y + margin);
				if (points[0].X > points[1].X)
					Canvas.SetLeft(baseTextBlock,
						points[0].X - linkBounds.X - margin - measure.ActualWidth);
				else
						points[0].X - linkBounds.X + margin);
		static public DependencyProperty BaseTextProperty = DependencyProperty.Register(
			"BaseText", typeof(string), typeof(MyLink), new PropertyMetadata("", OnTextChanged));
		private static void OnTextChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
			var link = (MyLink)d;
			link.UpdateVisuals();
		public string BaseText
			get { return (string)GetValue(BaseTextProperty); }
			set { SetValue(BaseTextProperty, value); }
		private readonly TextBlock baseTextBlock = new TextBlock();
If you let users draw links interactively, you must also create a custom behavior class and assign its instance to diagram.CustomBehavior:
public class MyBehavior : LinkShapesBehavior
	public MyBehavior(Diagram diagram) : base(diagram) { }
	protected override DiagramLink CreateLink(DiagramNode origin, Point point)
		return new MyLink(Diagram, origin, point);
