Normal Topic Display menu when clicked on node (Read 2993 times)
krantir
Feb 7th, 2012 at 2:25pm
I am trying to display a menu when clicked on node at the mouse clicked position. When i use the node clicked event i am capturing coordinates using
args.mousePosition["x"]
args.mousePosition["y"] but that is not the desired position.
I have my menu in the div tag.
Can you please suggest a better way to get the coordinates when clicked on a node to display the menu. Iam able to get the correct coordinates using canvas click event
  var x = e.pageX;  var y = e.pageY;  var o = {left: x,
top: y };  $("#maindiv").offset(o);
Thanks.
Re: Display menu when clicked on node
Reply #1 - Feb 7th, 2012 at 3:55pm
You could call diagram.docToClient to convert mousePosition to canvas-relative pixel coordinates. Then if you need them relative to the page, add canvas.offsetLeft/Top to the point. Alternatively, store the pageX/Y values from the last mouseMove/mouseDown handler and use them in nodeClicked.
Perhaps we should add a rawEvent member to NodeEventArgs, similar to what the MS.Ajax library does for mouse events - that will let you inspect the original pageX/Y or clientX/Y values. I'm not sure if our developers will be able to make it for v1.3 though, we are very close to release now.
