Normal Topic Can I set the Resource Header Back Colour? (Read 5135 times)
Rob Branaghan
I Love 2 Code!!
Feb 8th, 2012 at 1:26pm
Hi Meppy,
Is it possible to do the following for that Lane only??
 GanttChartControl.ResourceViewSettings.Style.HeaderBrush = myresource.CustomBrushes.PrimaryBrush;
Because I need to make the Header row have the same colour as the lane, but the lanes can be different colours.
Robert Branaghan
.NET Software Developer
FactoryMaster Ltd.
Re: Can I set the Resource Header Back Colour?
Reply #1 - Feb 8th, 2012 at 1:56pm
Unfortunately this is not possible out of the box, you need to rely on custom drawing. Set the Calendar.CustomDraw property to CustomDrawElements.ResourceViewRowHeader then handle the Calendar.Draw event and perform the necessary drawing. However, because the event is raised after the header's default appearance is drawn, you will have to repaint the header text too.
Rob Branaghan
I Love 2 Code!!
Reply #2 - Feb 9th, 2012 at 1:38pm
Do you have any code examples that can do this?
Robert Branaghan
FactoryMaster Ltd.
Reply #3 - Feb 9th, 2012 at 3:15pm
Check the attached sample.
_sample_ResourceViewPaintHeaders.zip (Attachment deleted)
Rob Branaghan
I Love 2 Code!!
Reply #4 - Feb 15th, 2012 at 4:04pm
Brilliant!
Now all I wonder is can I put some style to it? because I would like to have almost a Drop Shadow or gradient colour.
Can this be done? and How?
Robert Branaghan
FactoryMaster Ltd.
Reply #5 - Feb 16th, 2012 at 7:29am
The above sample paints the header with the CustomBrushes.PrimaryBrush property of its associated Resource. To paint the header with gradient, simply assign a gradient brush to this property (or customize the custom drawing code to use a gradient brush directly). Drawing a shadow outside of the header's bounding rectangle shouldn't be a problem because there is no clipping at the time the header is custom drawn.
